They are actually limited by the controller itself. So the controller will only ask the driver to make moves up to a certain speed. Then the driver converts those requests to electrical signals that get sent to the motors.
Theyâre limited by whichever thing is slowest.
An 8-bit GRBL controller can output a maximum pulse rate of about 30,000 steps per second
- This means that if you have a high steps/mm value, youâll have a lower maximum speed you can reach. (yours is 80 steps/mm, so in theory, you could get to 375 mm/sec)
Stepper motors themselves will have a maximum RPM for a given voltage. If the above speed causes the steppers to spin above this RPM, you wonât be able to go that fast
Stepper motor drivers can usually handle 100,000 steps per second or more - the spec sheet for the chip on the driver should probably tell you this, but theyâre rarely the limiting factor.
