Problem with Monport K40 pro x axis in Lightburn
Hello! I have just received a new Monport K40, this is connected to Lightburn. Everything looks OK, but for some reason the X axis is mirrored. When I try to run a test in from LB, I see that the cursor goes to the left outside the working area, and it stops at Alarm 2, laser head out of working area. Tried to change in machine settings but it doesn’t seem to be correct? Homing works as it should on startup. The motherboard is Monport 2. GRLB 1.1
My settings:
$0=10
$1=25
$2=0
$3=4
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=6
$24=1500.000
$25=3000.000
$26=250
$27=25.000
$30=1000
$31=0
$32=1
$33=1
$34=1
$35=0
$36=0
$37=1
$39=1
$100=160.000
$101=160.000
$102=800.000
$110=8000.000
$111=8000.000
$112=100.000
$120=600.000
$121=600.000
$122=20.000
$130=300.000
$131=200.000
$132=200.000
ok
First, undo whatever changes you made to the settings. Restoring from an automatic backup may be the simplest way to be sure:
After doing that, most likely the LightBurn machine origin is in the wrong corner, so this troubleshooting description should straighten it out:
That will eventually take you to the Device Settings page:
