Problem with Ruida wrong speed wen send with LightBurn with Bridge
Good afternoon. I have a problem with my ligthburn bridge.
If I send the file with speed 100 power 90. my BRM laser with Ruida 6332G controller shows the right power but not the right speed. Is this a setting problem of ligthburn or my BRM laser
Can’t tell from this description… Lightburn or the it’s bridge probably is not the culprit…
I’m not sure how you mean it’s only getting there with a slower speed. Lightburn has it’s speed set in mm/min, mm/sec or in the imperial mode of inches/min … so a speed of 100 means less than nothing, since it has no ‘units’ associated with it. Some manufacturers use speed based on %…
Limits can be set in the machine and Lightburn needs to be configured correctly…
Where do you see the change and how did you set up Lightburn… Assume this is new…?
