Issue with traced outlines
I am creating images in LightBurn for use with my Atomstack A20 Pro. I want to trace the perimeter of an object and separate the traced outline from the original object layer so I can cut around it. However, the resulting lines are not clean or crisp: they appear fuzzy, disjointed, and as though they are pulsing, with numerous dots and short line segments. When I select the outer lines and try to convert them to a separate line layer, the process does not work doesn’t create a new cut layer.
Request for help
Can anyone advise whether the trace or sketch settings can be adjusted to produce a cleaner, more continuous outline? I am new to laser engraving and would greatly appreciate any guidance.
