I have a problem with my R3 rotary. The direction on Y axis is moving oppositely. Anyone can advise how can i solve the problem. When i set the laser position it will move oppositely and lightburn will trigger “cut might be out of bounds” when i click start
In the Rotary Setup box, test the ‘Mirror Output to Rotary’ switch and see if that generates the output you are looking for.
The ‘cut might be out of bounds’ is likely an expected error when using a rotary. There may be some words around it stating that the engraver hasn’t been homed or the position isn’t known. If you copy and paste the error message with a few lines from each side of it into a reply here we can take a look and see what’s happening.
This could
