Non funzionano più i layer colorati, Lightburn incide e taglia senza seguire la numerazione, come si può risolvere?
“The colored layers no longer work, Lightburn engraves and cuts without following the numbering, how can this be solved?”
What do you mean when you say :"…without following the numbering…"?
Tell us what steps you are taking and the results you expect, then tell us what is or is not happening when doing so. The details are important here to best assist you. You can post images if that helps you illustrate what you are experiencing. We are wanting to “see” what you are, and your details are required.
