al conectar el rotativo a sculpfun no se mueve el modulo .
When connecting the rotary to sculpfun, the module does not move.
Explain how you connected the rotary. The rotary motor is basically the same as the Yaxis motor. Just be sure you do not do the connections with the power on.
Does the machine work normally when you restore to the original connections?
Here is a little link explaining most steps with a rotary:
