Bonjour,
J’ai un laser ortur master 2 pro avec un windows 7.
Lightburn ne connecte pas le laser.
Les pilotes pour windows 7 sont pourtant bien installer.
Merci de votre aide.
Hello,
I have an ortur master 2 pro laser with windows 7.
Lightburn does not connect the laser.
The drivers for windows 7 are however installed well.
Thank you for your help.
Do you see a Port assigned to your laser in Device Manager when you have the laser plugged in and turned on? Can you take a screenshot of this?
Also, there are a few different versions of the Ortur Laser Master 2 Pro. Is yours the original one or does it have S1 or S2 also in the name? The driver required changed between the original and S1.
