Problème de connexion usb
Bonjour,
je suis debutant
et j ai ce message qui vient … j arrive pas a conecter mon laser avec le usb
mais pourquoi??
Port failed to open - already in use?
En attende de connexion…
[MSG:25:Info: USB SERIAL STREAM CONNECTED]
Ortur Laser Master 3 Ready!
OLF:211.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
[MSG:20:Power Supplied]
ALARM:11
[MSG:13:Warning: Homing cycle required]
<Home|MPos:0.000,0.000,0.000|Bf:63,32758|FS:0,0|CL:0,0|PS:2,0|VA:24529,18|Ov:100,100,100|A:SFM>
[MSG:69:Info: WIFI AP READY]
[MSG:76:Info: WIFI STA DISCONNECTED]
[MSG:75:Info: WIFI STA KEEP TRYING CONNECT …]
Seems wifi and usb both trying to connect. Can you disable wifi?
Unplug usb connection, JUST power
Seems your power adapter is either failing / the wrong one and you are just bootin the motherboard
Does homing cycle happen at all?
