Bonjour, mon laser c’était déréglé la semaine dernière.
le X était inversé. Suite à la réponse de l’un d’entre vous, j’ai réglé le problème grâce à la formule $3=1.
Some manufacturers do not allow their GRBL parameters to be changed. Sounds like yours can, and it worked for a while, correct?
Usually, the parameters remain unchanged through a power down and power up cycle. Using the Console window, enter $$ and examine the list for the $3 value.
If you used the $RST=# command, it will revert back to the factory settings. Did you by chance do this, or possibly changed $3 through one of the Lightburn windows?
Seulement le problème revient.
I thought you meant it changed from $3=1 back to $3=?.
Are you saying the change to $3=1 fixed it, then it was not fixed when you powered up, AND the parameter is still $3=1?.
I am having difficulty understanding what is the actual problem. What is it that the machine is doing wrong?
If my questions are confusing, do not blame Google, blame me.
