Problemi con fil pdf
buongiorno vorrei sapere perchè alcuni file pdf non si riesce a gestire col sw lightburn (seleziona un particolare )
If you use Import (or drag and drop to the Lightburn workspace), you should have no problem with a PDF file. Of course, this means the PDF must conform mostly to the PDF standard.
I have not had a single problem Importing a PDF into Lightburn. If you have one that will not Import. add .TXT to the extension and include it in your reply.
