Hi guys, i make some rotary engraving last night… today a want to make engraving on a flat surface. i put back my default setting . when i try to set a laser position on the plan a received a error 9
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Pro Ready!
OLF 152.
[MSG: Flame detector Inactive. Luminosity too high]
Think i just did in Facebook
But i found the issue
You are homed, at 0x0
You are then requesting the machine to do a Job start, current position (0x0 for all machine knows)
Where your start is center
So machine thinks its at 0x0 and needs to move -10x -30y
It wont let you
Sugestion.
Home… move head to x200 y200
THEN adjust the head by hand to where you want.
no more alarm 2
