I save project A with layer 1, colored blue and renamed from C01 to, for example, half cut, with the settings power 50% and speed 100mm / s.
I would now like to start a new project (B), which has nothing to do with project A.
BUT:
If I would now like to assign a layer C01, I don’t get the standard settings, as with C02, where I had not made any changes in project A, but instead of C01, half cut is written there and the power and speed are not standard either , but as changed in project A …
where is the problem?
I would like to have the same standard settings for every new project and not waste time first having to reset everything manually
is there a solution, too, to rotate an object and after hitting enter it does not go back to zero? so i can adjust after entering, because i know, how much i rotated it.
and if i rotate it with the arrows, it doesn´t show me any numbers at all
Nice that you succeeded, please kindly mark the problem as solved.
What you write about rotation of shapes is correct and I also think it is not optimally solved. We can hope that it is on the wish / to do list.
