running LightBurn 1.4.03 on MacBook Pro running MacOS Sonoma 14.1.1
OK here is my problem. Have a file open and when i import another file into it i keep getting the same problem, not being able to deselect the items i have imported. It doesnt happen every time but enough to be annoying i would say probably 30-40% of the time. Any ideas i have restarted, reopened files, shut down everthing restarted laptop problem keeps arising SOMEBODY HELP
Yes you can press escape but this is not how it usually works, you used to just be able to click anywhere on screen to deselect. Why has this stopped working? When you press escape this sometimes has different affects on what you are importing. Sometimes it ungroups parts which is not ideal.
If multiple shapes are selected, clicking on one of them leaves all of them selected. If they’re grouped, the same sort of thing happens.
The trick, such as it is, is clicking on a blank area within the selection that’s far enough away from the shapes to not fall within the object snapping distance.
All of that can be difficult with a crowded selection, but it still works.
Either of these methods should work and should in fact be equivalent.
@ednisley has called out techniques to do that with clicking out of the selection.
This part is not making sense to me. By default imports will be grouped. Nothing you do from a selection perspective will change that grouping either through click or ESC.
Do you have a specific example .lbrn file that you can upload that demonstrates this happening? I will try to reproduce the issue.
this is not a specific file it is all files i import a file all objects are selected, you used to be able to click anywhere and everything would be deselected. Now as i say 30-40% of the time this does not happen. I press escape they deselect, then if i select an object if i select another object it is like i am holding shift down and selecting another object.
Just tried that Ralph, that seems it would cause a whole lot more problems as when you import nothing is selected. So when you import 1 file on top of another file this causes 2 files to be mixed up
