Problems whith undoing while in node editing
I’m finding an interesting problem with Lightburn, sometimes when undoing while using the node editing tool nothing will happen until I go back to the select tool, then undoing will work as usual. I can not figure out what is happening, for the problem persists across devices.
Instead of going back to the Select tool, try just pressing the ‘ESC’ key to de-select the last node you edited. You’ll be able to undo as normal at that point, while still keeping the Edit Nodes tool open.
intresting thank you for your help?
