Problems with cutting sequence, please help!
When laser cutting multiple products with holes, the machine is going to do all the holes first before doing the outside.
The problem that then occurs is that the plate deforms and the holes are no longer in the right place.
I have the holes first option on. If i turn off the option it becomes total chaos.
Layer and priority does not seem to be the solution here either
I can regulate it with grouping, so that he first cuts the holes of the group/product and then the outside, but this is not doable with large numbers and different shapes. Automatic grouping doesn’t do it here either.
Who can help me with this quickly.
thank you in advance
Read this about optimization settings.
Optimization Settings - LightBurn Software Documentation
