I just purchased an Annoy Tools 10 watt (output) laser. When I load an image and attempt to frame it, the laser moves around the perimeter of the image, but does not turn on the laser on low power as expected.
I can not find any information on line for Annoy Tools lasers, so I am wondering if anyone else has one, and if Lightburn is familiar with this unit. It uses GRBL version 1.1f.
3 things you need to do to get this to work:
- Enable the “Enable laser fire button” in Edit->Device Settings
- Set power level to around 0.3% for the fire button in Move window. Increase this as necessary until you see the light. Make sure you’re wearing eye protection.
- Hold shift key as you click frame.
Thankyou
That solved the problem.
Lots to learn!
