Problems with project.
I have already thrown away 8 thermos flasks because I haven’t been able to get the image applied correctly.
I’ve tried using SVG, JPG, and PNG files, but things consistently go wrong at around the 75% mark. It’s as if the laser suddenly shifts by half a centimeter for no apparent reason. I’ve already tried a few tips suggested by Gemini, but nothing has helped. I initially suspected my laptop might be entering sleep mode, but I’ve disabled all such settings. I’ve reduced the speed from 3000 to 2000, and—since the print takes about 75 minutes—I’ve also been cooling the motherboard (which Gemini suggested might be an issue during such an intensive print job). The rotary attachment rollers are properly adjusted, the belts are sufficiently tight, and I don’t encounter any issues with other print jobs.
This should be the first lesson to be learned. Whenever possible, use disposable material for testing before engraving the final version.
mm/min I assume, or mm/min?
Since I don’t use the rotary system, I don’t usually pay that much attention. But I believe I’ve seen a reported case where something identical happened, in which the problem, if my memory serves me right, had to do with a rapid movement (return of the Y-axis, I believe) causing the cylinder to slip on the rollers.
If the problem always manifests itself in the same place, it may be related to this.
Looking at your image I’m going to suggest that you have a slightly loose set screw on your Y axis allowing the shaft to slip. The reason it doesn’t manifest initially is heat. the longer your run the job, the warmer the shaft and pulley get and metal expands with heat. This allows it to slip ever so slightly when it reverses direction.
Loosen any set screws on the pulley, check if there is a flat spot on the shaft and realign the set screw with that and tighten well. If no flat spot, just retighten the set screws very well.
See if that resolves your issue.
Hi Dave, welcome to the Forum. :tada:
It would help a lot and reduce questions if you told us the type of rotary you are using.
A wheeled rotary and a chuck usually work differently. The chuck allows you to grasp the material and a wheeled unit can slip.
As @thelmuth stated it could be something as simple as a grub screw working out or more complicated as @Kuth advised, you may have to change the acceleration values, which can effect your speed.
I have both types. When I used the wheeled rotary, it’s easy for it to loose traction when rotating the mug/cup.
Lacking information on what hardware you’re using. :thinking:
:grinning_cat:
Absolutely true. It can not only slip with the rollers losing traction as it rotates, but it can also shift end to end, which is another big possibility given your images.
You can see that from his images, I just wanted him to confirm what we already figured out.
:grinning_cat:
Thanks for your response.
Testing is indeed a good approach, but I’ve already produced several bottles using this setup without any issues.
Besides, this design is nearly circular, so there isn’t much room left to run another test.
Oh well. I can afford the 4 euros per bottle, though it’s a shame, of course.
I’ll keep your tip in mind for next time and reduce the speed even further.
Thanks for your responses so far.
I’m still a rookoe when it comes to laser engraving, so apologies for omitting some details.
I’m using a Sculpfun Rotary Roller with a Sculpfun S30 Pro.
Up to now, I’ve mostly engraved wood, paper, and a few thermos flasks—all of which turned out fine.
I had one flask left, so I tried engraving a completely different design on it using the same settings that had caused issues with my previous attempts.
This design engraved perfectly, with the flask completing a full rotation.
That’s why I’m puzzled as to why it only goes wrong with the GTA logo, which is what led me here.
I’ll go over all the bolts and screws again. I did discover some debris in the guide rail, which was preventing the laser from moving smoothly.
I cleaned the rail and removed and lubricated the carriage block (where the bearings are housed).
After that, it was gliding perfectly again—but the problem persisted. I’ll try out your suggestions and report back with the results.
I’m heading off on vacation, so please bear with me—I’ll follow up once I’m back.
I was also in doubt, only when I read:
I realized it was the rollers type.
When you mentioned that Gemini had suggested some causes and that you had already checked the belts, the tightness, etc., I deduced that Gemini had suggested that cause in the first place, as well as that you had removed any debris.
I’m glad the “problem” is just that and nothing more complex. What worries me somewhat is that, in my view, debris should cause problems in all jobs involving areas with debris. :thinking:
Hello everyone.
Today, I finally had time to run a couple of tests.
I followed your suggestions and performed a clean reinstallation of LightBurn 2.2.0.
I moved the rotary attachment to the left side of the work area (it was previously in the center) to rule out the possibility of it hitting the end of the axis.
The belts are properly seated and have the correct tension. I also had someone else check the file, and they couldn’t find any issues.
I double-checked all the nuts and bolts and then started the job.
At 95% completion, I was feeling quite optimistic—it seemed the problem was gone—but then, at 98%, the design shifted again.
I stopped the job, adjusted the position of the rotary attachment slightly, and then finished the design.
I then tried a different design with a different type of bottle, but that one failed at just 25%.
I have no idea what else to try. I think I’m just going to give up on this rotary attachment and sell it; it’s becoming absolutely hopeless.
Show us your setup from a couple different angles. Tumbler on the rotary, ready to burn.
It’s certainly very strange.
When the problem occurs, do you hear any unusual noises?
I’m wondering what kind of mechanical failure could cause this problem, and I can only think of debris or faulty bearings.
A problem at the motor control level, like a bad connection, seems unlikely but not impossible.
