Hi, my laptop pc is running windows 11 and lightburn 14.0.3. I just upgraded my ortur lm3 to a 20w ortur module. I am noticeing that there is a delay in response to inputs in the software, not the machine. But when I am changing a size of an object or text or moving something, there seems to be a delay between my input and the results on the screen. It wasnt there before I changed laser modules but not sure if its related. Any thoughts?
It’s almost certainly not going to be related to the laser module.
Has anything changed on the computer side? New hardware, software, or an OS update perhaps? You may want to try rebooting as well.
Hi Rick,
I get some intermittent lag also when Lightburn does an autosave.
I changed the autosaves from 2 minutes (I think that is the default) to 15 minutes. That seems to have helped on my PC, To get to the setting go Edit> Settings >File Settings.
Cheers,
Rob
Nothing changed and I thought of that and rebooted.OS is regularly updated automatically.
Thanks will try tommorrow
One thing I just did is that I change from a cable connection to wireless connection from my pc to my lase. I just plugged the Ethernet connection back in but not sure if that overrrides the wireless. I think I need to change it under my devices tab. I heard you can get some issues with wireless. Maybe that’s what i am experiencing. Will try that also tommorrow.
