I can only get my machine to move back in fourth in the left front corner only and homes
It go straight up the side about 4in and then diagonal to the bottom out about 4in and home
But when I run lasergrbl it will do everything
Why
Allen,
From the limited information in your request for assistance is not helpful.
You will be more likely to get a reply if you include pictures to help illustrate the issue.
Include, Lightburn settings, device settings, Lightburn Cuts/Layers and results of the burn.
There are a multitude of reasons why a laser does what it does, so you need to help to narrow the issue down.
Have you checked the connection on the end of the gantry, they often come loose and causes the laser to run against the side.
