When i try to do a project and hit start it keeps saying that it is paused or stopped. I hit escape on the control board but still nothing. I went into settings and it will not read the machine. Im lost. It will do a project that is on file in the machine so i know the laser machine works. I hope you can help.
If you power the machine first, then run LightBurn, you should see something like this in the bottom of the display:
That “Found xxxx” message is LightBurn saying it has successfully identified and connected to your controller. If you don’t see that, it’s not connected.
- What kind of computer are you using? (Windows, Mac, … ?)
- Did LightBurn find and configure the laser when you set it up?
