When i load a project, nothing shows up on the display. The Cut/Layers shows up with the correct data, however nothing shows up on the grid.
Upload the file here if it is possible for you, it makes it easier to troubleshoot.
I’m guessing there are objects far from the workspace… use ctrl-shift-A to bring the objects into a framed view.
Thanks, not sure how all my projects ended up way off the grid line.
This could happen if you changed device settings or device possibly.
