Project piece in reverse location
I’ve searched for this question before I posted… I draw a shape. I select the location icon to move the laser to the shape. It goes in the opposite direction. Shape is lower left, laser goes upper right. Framing does the same.
I’m sure it’s a simple fix, thanks so much.
FYI My machine origin is set at back right.
UPDATE: I got the location to be correct, not sure how. But framing is still doing the opposite. ugh.
It’s usually caused by having the origin (Home) location set wrong in LB Device settings.
