Here’s a strange one, but probably a simple fix, but can’t seem to put my finger on it…
I have 2 PC’s with lightburn installed. One connected directly to the laser over usb, and the other connects over my network. The one connected via usb works fine, but the one over the network sends everything to the laser ‘horizontally flipped’ It looks fine on screen, and if I open it on the usb device it also shows it flipped…
Any clues?
Thanks in advance
The solution is to make sure your “device origin” in “Edit>Device Settings” is set to the same point on each of your PC’s, that was my problem, and is now all good
