Liebe Lightburn Familie!
Ich habe ein Atomstack A10 pro - Ich habe bereits einige Projekte probiert. Mein Problem ist aber, dass ich nie wirklich in die Mitte komme. Es ist leider immer schief… kann mir jemand damit helfen?
Danke
Danke
…in relation to design or your machine bed…can you show a simple example?
Ich habe runde Holzlatten und wollte da einen Spruch gravieren. Die waren aber schief und nicht in der Mitte eher seitlicher
Is your centering problem in design or when you are trying to laser it with your laser after you have sent the drawing to your laser. Screenshots of your design and the settings are always welcome and make the problem more visual for others.
If it is a positioning problem of the design in the laser and/or if you are going to make a lot of them, you should make a template. Find a piece of wood that is larger than your desired design, position it on the machine bed where you want it and cut the outer edge of your design with +0.5 mm oversize (offset). Make sure to fix your template on the machine bed so that it cannot move at all. Now you put your roundels in the template hole and press start.
It is even easier if you use absolute coordinates and if you have fixed existing edges on the side edge of your machine bed that you can use as reference points/boundaries, then you save the template and the file that belongs to the template and can find it again in a year and continue making Christmas decorations
