Buongiorno ho un problema con il mio laser VEVOR L4681, con il software lightburn non riesco a portare il laser a 0, il laser funziona ma non trova il punto 0 e i comandi che gli do manualmente sono al contrario sulla console quella con le frecce che sposti il laser manualmente qualcuno può aiutarmi?
Good morning I have a problem with my VEVOR L4681 laser, with the lightburn software I can’t bring the laser to 0, the laser works but it doesn’t find the 0 point and the commands I give it manually are the opposite on the console, the one with the arrows that move the laser manually. Can anyone help me?
Some engravers find the Origin or the Home position when turned on, even when they are not successfully communicating with a computer. This Homing process relies on the settings that are internal to the engraver.
When an axis is behaving backwards in LightBurn, it’s most often an incorrectly selected origin position.
To correct the behavior of the axis, select ‘Device Settings’ along the top row in LightBurn (the icon is a wrench and a screwdriver). In the Origin setting, (the four circles), you can reverse the behavior of the axis by selecting the other circle, in the direction of the axis you want to change.
After you have reversed the X-Axis, the Y-Axis, or both axes, click OK at the bottom right of the Device Settings window.
Retest the ‘jog behavior’ of your engraver.
Please reply here to let us know if this resolves the reversed axis.
