Purchased a file from ETSY. PNG when I import into Lightburn and try to adjust it nothing changes
I purchased a PNG file from Etsy of a F22. It looks good but a bit dark. I imported it as a PNG to my file i am working on and am not able to adjust the gama. I select the image then click adjust but when I adjust the gama nothing happens. I am attempting to just a jarvis format. What am I doing wrong ?
Just tested with a PNG file. You should definately see some difference, if the image is more than 2-color (B&W).
Hi @fureverangelaquamation
Is the PNG a grayscale photograph, or has it already been converted to a black-and-white dithered image?
If the image has already been dithered, adjusting Gamma won’t have the effect you’re expecting.
Could you upload the original PNG here (or as you paid for it, perhaps if you prefer email it to support with your original question support@lightburnsoftware.com), along with a screenshot of your Adjust Image window? That will help us see what’s happening.
My main suspicion is that the Etsy seller has supplied an image that’s already been processed for engraving. If it’s essentially black and white rather than grayscale, there may be little for Gamma to adjust.
It sounds like the PNG may already be black-and-white or dithered, so Gamma has no grey tones left to move. I’d go back to the original colour or greyscale image, adjust that, then dither once — in LightBurn or outside it, but not both. I’ve been using this free browser tool for that prep stage: Image Preparation for Laser Engraving — Makers Army . It can give you a fresh greyscale or dithered export, but it can’t bring back tones that are already gone.
