Hi and thanks for your help.
I have must 10W Creality Falcon now for a month and still doings test cuts. (Currently testing 2mm MDF)
I need to plug into you who have years of experience.
Is it better to go slower and push for a 1-Pass cut @ 100% or go a bit faster at a lower percentage and do 2 Passes? Which one will produce a “cleaner” cut and don’t cause a lot of “charcoal”?
Thanks very much.
I go the less cuts. is better, but I don’t know if it’s better. My thinking is numerous cuts are subjecting the sides to more heat and charring.
Interestingly enough, I subscribe to the more passes, lower power school. I have a feeling which performs better depends on how air assist and air flow around the part is set up.
Lower power and more passes produces a cleaner cut for sure.
