Push to front/back and draw order doesnt work
i cannot select the right square from where my cursor is, it allways selects the left one which i have placed first.
regardless of how many times i press the arrange - move to back / front or press page up or down button, changing the draw order doesnt do anything either
this is just a example, i have other work where a object is fully overlapped by another one and i just cannot select it at all without moving the top object first
clicking a object again on the same spot should select the object below, then the one below that and so on.
Turn off filled rendering, switch to wireframe. Then you can make your moves. Window Menu>Wireframe. You can toggle it on and off with the Keystroke Ctrl-Shift-W
-or-…
Put the objects on different layers and set the order of the work-flow (and hence the stacking order on screen) in the cuts and layers window by arranging the layer in order of operation.
Switching the view worked!
but putting those on a different layer defeats their purpose
