when i use the qr code generator the squares are just outlines. i must be doing something wrong. can i load an image of the screen?
The squares are just outlines because you’ve not set the layer they’re on to Fill. The LightBurn edit window shows wire outlines for everything by default, so use the Preview button to see the fill, or go to Window > Filled/Smooth to see the edit window in filled mode. (We don’t recommend using this all the time, just for spot checking work - some things are harder to see in filled mode)
