I am have so much trouble getting images to burn correctly on to tile without getting vertical lines in them. While I have been reading as much as I can on the subject the documentation states “to be completed later”. Is there time frame as to when this will be completed because I could use any help I could get with this subject.
https://lightburnsoftware.github.io/NewDocs/EngravingImages.html
Not sure exactly what you are doing, but image engraving is one of the most tricky.
If you are using the ‘Norton’ method there are a lot of threads around for that topic on this board.
It also helps with a picture for us to ‘see’ what you see and don’t like. If it’s not a problem, the project .lbrn2 file. That helps us eliminate any issues that are common.
Good luck
Forget this part?
4 tile burn.lbrn (2.8 MB) sorry about that i knew better
4 tile burn.lbrn2 (2.8 MB)
A picture of the tile with the aberration you’re trying to describe is very helpful.
Sorry, I should have been more specific.
I know you know what it looks like…
