Question on framing vs project
when i frame i use the fire button to reline a project, but when i hit start the alinement is off .185 or more where did i mess it up at ty in advance
framing do not follow the lines of the project, is a little bit wider to let you see if is well aligned onto the surface you are engraving, or cutting
ty
i didnt know if there was a setting
