I used my Redsail M900 today, to do fills/wood engraving for the first time. I was burning text inside a perimeter. I was using the “Fill + Line” setting, to get a good interior fill on the text, as well as a quick ‘smoothing’ run around the edges of the text after filling.
I’m curious/confused about the different speed/power settings in the “fill+line” box. At the top of the box is a speed/max power setting, and then under the “line+fill” box at the bottom of the screen is another speed/power setting.
I’m assuming one of these is for the "fill’, and one of these is for the “line”? Can you confirm which is which?
I posted about this a few days ago and also had a question about line speed in the lower section. It seems to cut way faster than the setting in the lower window. Post title - Cut settings window
