Question regarding true nest in lightburn 2.2...before purchasing pro...I need an answer to a question\
I am a novice Lightburn 2.2 user. I am using a Lenovo Windows 11 laptop computer with 32 gig memory for the most part when using lightburn 2.2 core edition on a 10 Watt Creality Falcon CR-10 Laser with a 400x415 mm bed laser engraver. Presently, for the most part, I am buying designs on Etsy that are in svg format and have assembly instructions included on a pdf file. The svg files typically have 3 layers included (cut layer, engrave layer, and a part number layer). I have access to a lot of 300 x 300 mm plywood 3mm thick. Most of the files I am buying have many parts and are nested to fit different size sheets than the ones that I have access to. Up to now I have been grouping all parts and nesting them via svgnest. It is quite time consuming and have had varying results requiring fixing the results for lasering. In Lightburn 2.2 True nest sounds like a good alternative, but it requires upgrading to the Pro version with a cost of $100. Before I make the investment in Pro, and from what I read, I could avoid all of the grouping activity by ungrouping all imported svg parts in Lightburn and using the “lock all inside objects” for nesting using True Nest. If that be the case, what I need to know is whether after nesting, are all layers preserved such that I can unlock the part number layer, or not use it to send to the laser, to preserve the assembly, while preserving the re-nesting operation? Any guidance would be greatly appreciated.
Layers are preserved.
You can test True Nest by either deactivating your installation through the help menu and activating a trial (trials are always Pro) or downloading MillMage Pro and testing True Nest there. MillMage files will open in LightBurn just fine.
You might also like “Auto group” in the arrange menu. It goes through the drawing and tries to intelligently group shapes by objects contained inside other objects. Works very well in my experience.
