I have traced an image that contains a ribbon with text inside. I want the ribbon to be dark with the lettering being untouched. Any suggestions on how to do this? I have played around with different layers and maskings but can’t seem to get it. Next question after an image is traced is there anyway to change the “thickness” of the traced lines? Thank you
Make sure that the ribbon is a closed object and put the ribbon and text on the same layer.
Thank you I’ll try that !
Thanks that worked great!
