Qui peut m'aider
01/02/2023 16:31:29.786 Program ------- LaserGRBL v4.9.4 [64bit] START -------
01/02/2023 16:31:34.491 Update DB Material DB is up to date
01/02/2023 16:31:35.928 SetStatus Machine status [Connecting]
01/02/2023 16:31:35.933 OpenCom Open COM3 @ 115200 baud Ctrl-X (UsbSerial)
01/02/2023 16:31:35.937 SendImmediate Send Immediate Command [0x18]
01/02/2023 16:31:41.960 SetStatus Machine status [Idle]
01/02/2023 16:31:46.110 CloseCom Close COM3 [USER]
01/02/2023 16:31:46.111 CloseCom Close COM3 [CORE]
01/02/2023 16:31:46.113 SetStatus Machine status [Disconnected]
01/02/2023 16:31:48.012 SetStatus Machine status [Connecting]
01/02/2023 16:31:48.012 OpenCom Open COM3 @ 115200 baud Ctrl-X (UsbSerial)
01/02/2023 16:31:48.015 SendImmediate Send Immediate Command [0x18]
01/02/2023 16:31:52.480 Refresh Config System.TimeoutException: No response received from grbl!
01/02/2023 16:31:52.480 Refresh Config à LaserGRBL.GrblCore.RefreshConfig() dans E:\LaserGRBL\LaserGRBL\Core\GrblCore.cs:ligne 1003
01/02/2023 16:31:58.014 OpenCom Connection timeout!
01/02/2023 16:31:58.014 CloseCom Close COM3 [CORE]
01/02/2023 16:31:58.015 SetStatus Machine status [Disconnected]
01/02/2023 16:51:17.309 SetStatus Machine status [Connecting]
01/02/2023 16:51:17.310 OpenCom Open COM3 @ 115200 baud Ctrl-X (UsbSerial)
01/02/2023 16:51:17.313 SendImmediate Send Immediate Command [0x18]
01/02/2023 16:51:22.624 CloseCom Close COM3 [USER]
01/02/2023 16:51:22.624 SetStatus Machine status [Disconnected]
01/02/2023 16:51:23.679 SetStatus Machine status [Connecting]
01/02/2023 16:51:23.680 OpenCom Open COM3 @ 115200 baud Ctrl-X (UsbSerial)
01/02/2023 16:51:23.682 SendImmediate Send Immediate Command [0x18]
01/02/2023 16:51:32.945 SetStatus Machine status [Idle]
01/02/2023 16:51:40.933 SendImmediate Send Immediate Command [0x18]
01/02/2023 16:51:43.447 Refresh Config System.TimeoutException: No response received from grbl!
01/02/2023 16:51:43.447 Refresh Config à LaserGRBL.GrblCore.RefreshConfig() dans E:\LaserGRBL\LaserGRBL\Core\GrblCore.cs:ligne 1003
01/02/2023 16:54:10.095 CloseCom Close COM3 [USER]
01/02/2023 16:54:10.096 SetStatus Machine status [Disconnected]
01/02/2023 17:09:46.836 SetStatus Machine status [Connecting]
01/02/2023 17:09:46.837 OpenCom Open COM3 @ 115200 baud Ctrl-X (UsbSerial)
01/02/2023 17:09:46.840 SendImmediate Send Immediate Command [0x18]
01/02/2023 17:09:56.840 OpenCom Connection timeout!
01/02/2023 17:09:56.840 CloseCom Close COM3 [CORE]
01/02/2023 17:09:56.840 SetStatus Machine status [Disconnected]
01/02/2023 17:10:00.269 SetStatus Machine status [Connecting]
01/02/2023 17:10:00.270 OpenCom Open COM3 @ 115200 baud Ctrl-X (UsbSerial)
01/02/2023 17:10:00.273 SendImmediate Send Immediate Command [0x18]
01/02/2023 17:10:03.037 SetStatus Machine status [Idle]
01/02/2023 17:10:13.539 Refresh Config System.TimeoutException: No response received from grbl!
01/02/2023 17:10:13.539 Refresh Config à LaserGRBL.GrblCore.RefreshConfig() dans E:\LaserGRBL\LaserGRBL\Core\GrblCore.cs:ligne 1003
bonjour ,
J’ai un gros soucis, je ne peux plus rien faire sur laser grbl apparemment dans configuration il y avait un message me disant erreur de lecture de configuration
que dois je faire
Hello,
I have a big problem, I can't do anything on laser grbl, apparently in configuration there was a message telling me configuration reading error
what should I do
You may have better luck posting in a dedicated LaserGRBL forum like this group on Facebook: https://www.facebook.com/groups/lasergrbl/
Off the cuff I’d say you may need to download the CH340 drivers for your PC CH340 Drivers for Windows, Mac and Linux
