1st time used it in rc4, error with quick nest , no errors when using in rc3
true nest dosent bring up error
laundry cup.mage (5.9 KB)
i shut MM down , started whole my project and still doing the same
hmmm odd wonder whats causing it at my end
i select all and click quick nest .
I did add the blue rectangle to my template for that particlla sheet size after that is when i couldnt nesst , ill try deleting the saved rectangle , create new rectangle and nest again
Might be a long shot but I had some odd behaver (Not this) it was driving me crazy…turns out the template file I had been using was corrupt in some way so creating a new template and copying the shapes across fixed it for me.
picking you hit nail on the head , if no one else is getting that error , its got to be my template
I tried it too with no issues.
Now this is where it gets odd, so the original file ,every time i reopened the saved file it gives error .which is the same file which is attached to this topic
im not at workshop computer at present , so instead of going to find that file from other computer folder , i just downloaded it from this topic and boom working fine, hmmmm ?
one would think that if a file was casing an issue it would do it all the time, no matter what system its opened on
correct or incorrect ?
i will try it later today, the file in this topic and one on my computer and see what happens
file on computer still gives the error but file downloaded from here is sweet on other computer, we will just put that in the unexplained file and carry on
Could be a corrupt file or similar - let us know if it happens again! Marking this solved, for now.
