I love the new sliding radius tool in V1.5. BUT, I ran into a problem yesterday where the tool was extremely helpful in mataching an unknow radius. But I only need to of the four corners with a radius. I could not for the life of me figure out how to undo the radius on the corners where I didn’t want them. Ususally I simply click on them while using the radius tool to undo that radius. I’m guessing the slide tool doesn’t currently treat them as individual radi. Is this something that can be changed?
This is a clunky way to undo the unwanted radi. It seems to work, but only after converting to a path and only if you are hovering over a node of an unwanted radius. When undoing a radius generated with the old radius tool you simply click anywhere on the radius. It would be nice if the could work the same way after sliding to create the radi.
Try this. Use the sliding radius tool to get the radius you want, select the shape and go to shape properties, the radius dimension will be there. Undo your sliding radius and use the individual radius tool with that dimension on the corners you need.
