Ramp setting equivalent for 3d sliced images?
I was able to easily and quickly make stamps with tapered edges on my CO2 Gantry laser.
I want to be able to do the same thing on my galvo laser, without having to create a 3D depth map first. Is it possible to create simple text stamps with a ramp feature that ramps the edges of the text that can be used with 3D sliced image mode in lightburn?
If you set your shapes to Fill mode you get options to ramp. You may have to do a few tries.
The ramp setting when in fill mode creates the ramps by ramping up or down the power, I am wondering if it is possible create the ramps via 3d sliced image mode instead of altering the power.
Making ramped edges on metals would work better using 3d sliced more rather than by altering laser power
