Random path while engraving
Hello group. I am doing 12 plaques plates and these plaques have a logo. The laser will engrave a coulple of them then start again in a different spot. Is there a way to correct that and have the laser engrave them all in a row instead of randomly jumping to a different spot?
Thanks.
Optomization settings will do what you want. Use the preview window to see the results before engraving.
There are also buttons at the bottom of the Cut Settings Editor page that will modify the burn pattern.
I’ll check that out next. Thanks.
That seemed to help out. I’m going to play around with that.
Thanks.
That helped out a lot. Thanks.
