After several configuration tests, I noticed that when I activate the rotary axis, which should consequently set the Y-axis parameter changes, this doesn’t happen. Furthermore, after several attempts and tests, I noticed that when I activate the U-axis as rotary, the U-axis changes its parameters.
I wanted to know if in this RD6432 device, the rotary is no longer controlled by the Y-axis and instead by the U-axis, and if Lightburn has already set something up.
388 / 5.000
As the guy said, you have to change the parameters every time, and it’s not intuitive or simple. From my tests, I noticed that the parameters sent when the rotary is enabled must be received by the U-axis, so Lightburn should allow the U-axis to be used, which it doesn’t.
To recap, Ruida RD6432 changes the U-axis settings and not the Y-axis settings when the rotary is activated.
