Re-Homing Atomstack X24 PRO
Ciao, non riesco piu a lavorare con la mia macchina, continua a tremare l asse x quando cerco di farla muovere in un progetto.
L asse y si muove senza fare rumori.
lightburn continua a darmi sempre lo stesso errore:
Hi, I can’t work with my machine anymore, the x-axis keeps shaking when I try to move it in a project.
The y-axis moves without making any noise.
lightburn keeps giving me the same error:
ALARM:1
Hard limit attivato. È probabile che la posizione della macchina venga persa a causa di un arresto improvviso e immediato. Il re-homing è altamente raccomandato.
ho provato con $H, $$, $X
ma non sono riuscito a risolvere nulla
qualcuno puo aiutarmi?
Hard limit activated. The machine position is likely to be lost due to sudden and immediate stop. Re-homing is highly recommended.
I tried $H, $$, $X
but I couldn’t solve anything
can someone help me?
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:Y|WCO:0.000,0.000,0.000|APP:33|USB:0>
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:Y|Ov:100,100,100|APP:33|USB:0>
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:Y|APP:33|USB:0>
ok
ok
Avvio streaming
Start streaming
ALARM:1
Sulla linea o vicino alla linea 0:
Streaming completato in 0:00
Hard limit activated. Machine position is likely to be lost due to sudden and immediate stop. Re-homing is highly recommended.
On or near line 0:
Streaming completed in 0:00
[MSG:alarmCodeCodeIntHandle:1
[MSG:Program End]
ok
Grbl V1.055 [‘$’ for help]
[MSG:Check limits]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Does X and Y axis move in the right direction when you use keys to jog it?
Is it sitting on a limit switch?
Si muove l asse y, ma l asse x fa fatica a muoversi e continuana tremare e a volte si muove correttamente. Mi servirebbe il gcode per portare tutti i parametri originali allo stato di fabbrica
The y-axis moves, but the x-axis struggles to move and keeps shaking and sometimes it moves correctly. I would need the gcode to bring all the original parameters to the factory state
Si se lo faccio manualmente si muovono senza fare rumore. Il problema e solo sull asse x che non trova piu lo 0
Yes if I do it manually they move without making noise. The problem is only on the x-axis which no longer finds 0
Seems it’s not tripping the X limit switch.
The Pn:Y statement in the message above shows that the Y-Axis limit switch is activated. If the engraver module is not sitting near the X-Axis (where the limit is), confirm the extent of the false signal by manually activating the switch (by hand, or with some adhesive tape) and confirming the message status does or doesn’t change.
If the message changes when the switch is manually activated the switch is configured incorrectly or wired incorrectly.
If the message doesn’t change when the switch is manually activated, you may have a broken switch, or a broken wire. Both switches are likely to be identical and they should feel the same when pressed.
A final temporary diagnostic step would be swapping the X-Axis and Y-Axis limit switch cables at the Controller. If the Pn:Y statement changes to Pn:X then you know that the problem is in the hardware outside the controller. If the Pn:Y statement persists the problem is in the controller.
Please let us know what you discover.
Ho provato a fare quello che mi hai detto, l asse x non si muove piu. penso ci sia un cavo rotto o i 2 limit sono rotti.
è l unica soluzione che posso trovare.
l ultimo messaggio che adesso mi dice la consolle e questo:
I tried to do what you told me, the x-axis does not move anymore. I think there is a broken cable or the 2 limits are broken.
it is the only solution I can find.
the last message that the console now tells me is this:
ALARM:1
[MSG:Check limits]
ok
[MSG:Check limits]
ok
ESISTE UN COMANDO $ PER RIPORTARE LA CONSOLLE ALLE IMPOSTAZIONI DI FABBRICA? HO PROVATO CON $RST=$ E DICE QUESTO:
IS THERE A $ COMMAND TO RESET THE CONSOLE TO FACTORY DEFAULTS? I TRIED $RST=$ AND IT SAYS THIS:
$RST=$
[MSG:Settings reset done]
[MSG:Position offsets reset done]
ok
SCHIACCIO IL PULSANTE HOME E NON SI MUOVE PIU L ASSE X E COMPARE DI NUOVO L ERRORE:
ALLARM 1 …
I PUSH THE HOME BUTTON AND THE X AXIS DOESN’T MOVE ANYMORE AND THE ERROR APPEARS AGAIN:
ALARM 1 …
Repeat the position report request from your first post to confirm the status of the switches. If the switches are held in the activated state, you can get this ALARM 1 statement. If the engraver has an ‘activated switch’ and if the engraver can not back away from the switch, the engraver can generate this alarm.
I’m intentionally using ‘Activated’ and ‘Deactivated’ because the controller can be set up for switches that are either, ‘Normally Open’ (closed to activate) or ‘Normally Closed’ (open to activate). There are benefits and drawbacks to either hardware choice.
Unplug the switches and repeat the request for the report. This will show us how the switches are supposed to be wired.
  • If the switches are reported as not-active, then the controller is expecting Normally Open switches. These switches close when activated. A broken wire in the switch circuit will prevent the controller from detecting a switch that closes.
  • If the switches are reported as active, then the controller is expecting Normally Closed switches. These switches open when activated. In this case, a broken wire in the switch circuit will be detected by the controller as ‘stuck in the active state’. This is what I am expecting to be true for your Atomstack.
Please confirm the results of the Position report and which type of switches that your controller is expecting.
Yes, that is the command, and the engraver has confirmed that the Settings Reset command was successful. Please request the Settings report ($$) and the Information report ($i) from your Atomstack device in the Console window in LightBurn. Please copy and paste both reports into your reply here.
I am very interested in seeing the settings between $21 and $27. These will offer insight into the homing behaviour that Atomstack set up when the engraver was built.
Now that the successful reset has occurred, we can start with the factory settings for your engraver.
Did you return the switches to their original connection points and remove the adhesive tape after the previous test?
