Red Dot frame size not equal to cut size
Here is my issue. I know how to calibrate the Framing Red-Dot to the Laser-Cut Profile, but I need to understand why this happens. 1) I set a square in Lightburn to 80mm x 80mm. 2) I then Frame this square and measure the Framing dimensions, and it is 80mm x 80mm. However, when I Laser-Cut this square, it measures 98mm x 61mm. So what is at fault here…love to know please.
