Red Light coming on and stopping mid cut?
Hi, My first question on here. Twice now i have had a cut stopped with the red light coming on and cutting completely stopping. Everything was aligned correctly and cut was going really well, then nothing! its Omtech polar using lightburn. I was engraving on slate. Ventilation on. Can anyone help please?
How are you connected (usb - Ethernet) – Are you using start or send? My assumption is start as you have to have a machine console to run the job.
The Ruida will find overscan if it’s excessive when you load the file and attempt to run it. When you use start, only a part of the data is in the Ruida when it starts to run the job.
Try running it through preview with show transversal moves enabled. Head travel will show up as red. If any of these are excessive that could be the issue.
Thanks so much for the info. Yes, was on send. I shall give your advice a bash later.
