Trying to install new version update and get an error in the installer: “Unable to execute file in temporary directory. Setup Aborted. Error 5:Access Denied” What temp directory should I check for permissions? I have multiple other version updates done on this Lightburn install
I had the same problem - here is the fix…
I figured it out right after posting and noticed my PC Matic settings were not set to prompt for vulnerabilities, once I set to prompt I could always allow and install. Not sure why or how I installed the other versions unless PC Matic did an update and reset the levels to the autoblock
