Remove lines between forms and letters
Hello,
I built my own laser CNC machine.
Hardware: InterpCNC V2.1 controller
Control software: Mach3
I am using custom G-code in LightBurn.
G-code variant: GRBL M3
Everything seems to be working correctly :slight_smile:
I can cut out parts designed in Fusion360 and engrave images and text…
However, connecting lines are appearing between the various parts (letters or shapes)…
How can I get rid of them?
Any ideas?
Thanks in advance.
Chris
Can we get a file with the problem and maybe a screen shot?
You have to grab the code that turn off the laser in Mach3 and put it in the Custom GCode.
Also check if it needs an M05 instead of an M5.
hi, tks for your answers.
ok, in my custom gcode, Gcode Flavor is GRBL M3
I put off Variable Laser Power.
And in Layer, Constant Power Mode is OFF.
It’s seems to be cool. I have lots M3-M5
M8
M5
G0 X-0.142Y0.737
;Layer C00
M3
M3
G1 X0.042S0F100
G1 X0.083S31.9
G1 X0.042S0
G1 X0.126Y0.1
G1 X-0.042
G1 X-0.133S31.9
G1 X-0.042S0
G1 X0.085Y0.1
G1 X0.041
G1 X0.162S31.9
G1 X0.042S0
G1 X0.092Y0.1
G1 X-0.041
G1 X-0.163S31.9
G1 X-0.042S0
M5
Draw 2 squares 20mm side near each other and post here the GCode in a reply.
Most likely, GRBL is not set to Laser mode:
