I have an image that I traced via Lightburn and its a complicated trace. Every time I send the file to the laser I have to wait until it renders which is about ~10 minutes. Is there a way to save the rendered version so I can immediately start the job on the laser, instead of waiting 10 minutes?
Then, when you want to upload it to the machine, click ‘Run RD File’ and pick the file you saved.
Having said that, do you have “Remove overlapping lines” enabled in the optimization settings? That one operation can add a lot of time to complex files, so if you don’t actually need it, turn it off.
