Repeat marking erratic behavior
I have a rotary fixture on my fiber laser that has 20 stations. When I invoke the repeat marking feature, sometimes it reports that the position is something other than zero. I then hit the zero button, and then the go to zero button and the fixture remains at the first station as it should. When I run the job, sometimes (not always), the fixture backs up to a different station when it starts. It runs twenty items as expected and returns to the first station which doesn’t correspond to the station originally set to zero. Since my jobs are double sided, they are scrap because the top and bottom sides are out of sync. If I index to station 1 and set to zero again, the next batch runs perfectly. This behavior has occurred several times. Please check the software for a possible glitch.
