there is a small area that I want the laser to rengrave over is there any way to position it without starting the whole process from starting point. It is just one line I want to go over in the middle of the project
Yes, in the preview window there is a function “start here”, it works fine, however you have to stop the passage manually where you want to stop if you do not want to burn everything to the end.
