Resetting lightburn to original "Rotary" settings
I have a neje 3 max v2, I bought a rotary chuck. Their directions were screwy, and my install has the thing working, but it’s all out of whack. I want to attempt to reinstall it. Is there a way I can reset the Rotary setting to their original values before I try this? Without re-installing
I just used my chuck rotary for the first time recently. I do not think there are “default” Lightburn settings for it. I found using the chuck meant setting only one thing - mm per rotation. When this is correct, the Test button will rotate the chuck exactly 1 revolution, then reverse back to the start position.
My final setting (xTool RA2 Pro) was 162mm, which appears to be the circumference of the chuck.
From there, I adjusted the size of the work to fit inside the desired engraving area. All those other boxes in the Rotary Setup window were not changed (it took me a while to realize this). I was doing shot glasses with Expo dry erase marker, but had to switch to white acrylic because shot and bottle glass is apparently harder…
Here is some guidance on how to calculate the rotary settings for any device: Rotary roller - Diode Laser Wiki
